How big of a regenerator pipe to use
Postby afrowanksta » Sun Aug 16, 2009 8:40 pm
I am building an alpha stirling engine and I don't know what diameter
or length of pipe to connect the two piston chambers with.
The piston chambers are 3" in diameter and 6" long. This gives an
internal volume of 42.4in^3 for each piston chamber.
Can someone tell me or estimate for me about what diameter and length
of pipe I should use to connect the two chambers?
Thank You,
Mark
afrowanksta
First Name: Mark
Last Name: Stonewall
Response to How big of a regenerator pipe to use
Postby longboy4 » Tue Sep 08, 2009 3:44 pm
........use a 1/4 inch diameter copper tube for your regen. pipe to join the displacer cyl. to the power cyl. . Your length will be determined by the distance between these cylinders of course.
longboy4
First Name: D.
Last Name: Petersen
