High Temp Epoxy Piston Rings????
Postby burnit0017 » Wed Jul 07, 2010 6:12 am
Greetings, I am starting a project using a 2 cylinder V air compressor and try to convert it to Alpha Stirling. I found some links were small projects created there own pistons using high temp epoxy. Using their idea, I am going to try to replace the piston rings with high temp epoxy and add a dry lubricant between the high temp epoxy rings Hopefully this will give a good seal and reduce friction. Has anyone tried this before? Best regards
Concept Drawing
burnit0017
First Name: Lauri
Last Name: Koponen
company: RuneTec
Re: High Temp Epoxy Piston Rings????
Postby DIYStirlingGuy » Sat Dec 15, 2012 5:18 pm
Wow, what a great idea. I think this will work for engines that run at relatively low temperatures (200-300 Fahrenheit). Let me know if it works out.
DIYStirlingGuy my site: http://diystirlingengine.com/
DIYStirlingGuy
First Name: Justin
Last Name: Sparks
company: Sparks Information
Users browsing this forum: Google [Bot] and 2 guests
