by hengsteler08 » Fri May 09, 2008 5:31 am
I have to disagree with Mr. Hornbaker in assessment of the amount of waste energy (heat), and the delta-T. If you drive your average 4-cylinder car at dusk for 20 miles at 65 MPH then pull over, pop the hood, and look at the exhaust manifold, I bet you'll see it glowing a dull red or brighter. This corisponds to a temperature of about 900F. Mind you, this temperature was obtained while a huge amount of air flow was going through the engine compartment constantly cooling the exhaust manifold. If the manifold were shielded from air flow cooling, I'd be willing to bet a cookie that temperatures of 1200F+ would not be out of the question. If ambient air were ducted to the "cooling" side of a Stirling engine, a delta-T of 1100F is not out of reason. This heat could be used for Stirling or micro-turbine electric power generation. What to do with the extra electricity? For one, you could run ALL the items that suck power from the cars engine: water pump, power steering pump, a/c compressor, not to mention all the electronics, lights, fans, cd's, tv's, and may have some power left to put back into the engine's crankshaft. (I would love to see this coupled with the emerging "Brown's Gas" technology!)
