Determining Piston type/size
Postby j.lloyd.carter » Sun Jan 17, 2010 12:18 pm
is it easier to use a pistons from a car/motorcycle or manufacture
your own? Is tolerances very important or can you have some space
between the piston and wall cylinder?
j.lloyd.carter
First Name: Justin
Last Name: Carter
Re: Determining Piston type/size
Postby burnit0017 » Tue Jul 06, 2010 3:45 pm
Greetings, I am new to this forum and Stirling technology. The research I have done indicates piston seal is very important. If you use the piston rings you get a great seal but the rings increase friction and reduce engine performance, if it will work at all. I found some videos on you tube showing conversions of old compressor engines into Stirlings engine but they removed the rings and had a poor seal.
I am starting a project using a 2 cylinder V air compressor and try to convert it to Alpha Stirling. Again, I found some links were small projects created there own pistons using high temp epoxy. Using their idea, I am going to try to replace the piston rings with high temp epoxy. Hopefully this will give a good seal and reduce friction. I am hoping to get enough RPM’s and torque to drive a small permanent magnet alternator. What size project are you working on? Best regards
burnit0017
First Name: Lauri
Last Name: Koponen
Users browsing this forum: Google [Bot] and 2 guests
