Power Piston & Cylinder Materials
Posted: Tue Apr 14, 2009 9:54 pm
Hello everyone. As an engineering student, I have the opportunity
to create a displacement style Stirling engine with my peers in a
manufacturing class. The engine is similar to the one in this link:
http://www.cse.iitk.ac.in/~amit/courses ... main2.html
The crankshaft will be turning a fan blade, and a stand will be
created for the unit. There are other groups making fans so there
will be a competition for highest RPM...so performance and tight
tolerancing is key!
ANYWAYS, to my question. The parts have been divided and I am in
charge of machining the power piston cylinder and power piston.
Currently, the power piston cylinder will be machined from brass and
the piston from steel. This is what the plans call for and what
previous classes have used.
Of course, since I am responsible for a vital part, I want to make
improvements. After doing some research, it seems as though
graphite or PTFE are desirable materials to use because of their low
friction factors.
So, I'm looking for some input on this. What would you recommend?
Should both parts be made from the same materials (both PTFE or both
graphite)? What materials would be best for maximum sealing (ie max
compression)?
I was thinking of maybe making the brass cylinder with a sleeve made
of one of those materials, with a piston made from one of those
materials. Eh? That would for sure reduce the friction...as long
as maintaining a seal won't be an issue.
And if I get my hands on some PTFE, I can give some to my other
group members for some upgrades...such as the bushings in the power
and displacer connecting rod (which now calls for split brass
bearings).
Thanks for any assistance! I'm really excited for this project
tolerancing is key!
friction factors.
compression)?
bearings).
