Rotary Gnome
Rotary Gnome
Postby acacialiberty » Sun Sep 20, 2009 8:41 am
My concept is to get the cylinders to rotate through the
heating/cooling mediums to improve the heat ramp and movement. Two
parallel banks of 4 cylinders each, 1/4th of a cycle out of sync mean
that adjacent cylinders can be used in the Alpha structure so they
are very close, parallel to each other separated by a short tube and
a heat baffle.
Similar to a double bank of Rotary Gnome WW1 aircraft engines. Has
anyone done anything along these lines. Power is taken off the moving
bank of cylinders.
How can I post a small sketch without it getting rejected?
acacialiberty
First Name: Timothy
Last Name: Hosking
Re: Rotary Gnome
Postby stan.hornbaker » Sun Sep 20, 2009 12:34 pm
An animated Rotary Gnome engine (ICE) is shown by Mat Keveneny at
http://www.animatedengines.com/gnome.shtml
This should make an interesting model if you can pull it off. To post photos/drawings go to HOME Pg.> Community > Under Your Portfolio > Upload a Single Photo etc.
Response to Rotary Gnome
Postby acacialiberty » Sun Sep 20, 2009 8:40 pm
Hi - Sorry, there seemse to be a server error with what pictures I am trying to submit.
http://img44.imageshack.us/img44/781/stirlingrota.gif
acacialiberty
First Name: Timothy
Last Name: Hosking
Postby stan.hornbaker » Mon Sep 21, 2009 6:55 am
Can you upload just the gif image, not the entire web site? The forums will not accept URL's.
Suggestion: Place the two 'rotors' close together to minimize the 'dead' space in the connecting tubes/pipes.
Postby acacialiberty » Mon Sep 21, 2009 10:12 am
Thanks,
The Banks will be far closer than the diagram, eliminating most of that dead space. However there still needs to be space enough for air flow over fins.
I notice that like the original Gnome there will be an optimal revolution rate (totally unknown) that will drop off efficiency levels fairly quickly much outside that rate of revolutions.
The bore, stroke, transfer tube are particularly important if you don't want to quickly waste the gain the rotating motor achieves.
This is the server message I get:
could not open "/usr/local/aolserver/servers/foobar//0000Ur-145.GIF": no such file or directory 0000Un
acacialiberty
First Name: Timothy
Last Name: Hosking
Postby stan.hornbaker » Mon Sep 21, 2009 12:34 pm
Try copying the gif file "0000Ur-145.GIF" to your desktop before uploading from there.
Keep in mind that you are building a model engine that will be more tolerant of discrepancies in detail than in a Power Producing Engine.
Users browsing this forum: No registered users and 7 guests
