Working cardboard Stirling engine
Posted: Wed Jul 23, 2003 12:39 pm
by k.huenig
I am researching the possibility to construct a working Stirling
engine using cardboard (0.3 mm or stronger) plus materials like
aluminium foil, plastic rings as bearings, maybe a ballon etc etc.
Heat source could be a glass or bottle with very hot water or a small
candle (which needs special protection of the cardboard of course).
Has anyone experience in such experiments?
Or is there already such a thing?
In the long run my intention is to offer a low-priced cardboard kit
to schools etc.
Klaus
Response to Working cardboard Stirling engine
Posted: Sat Jul 26, 2003 7:35 am
by richcorbett
Your project certainly sounds challenging! I would expect that you will run into a variety of problems from heat conduction to obtaining consistant seals with cardboard and adhesives in classroom use. I think it is do-able ... but would question the success rate associated with constructioning a Stirling made from these materials. I find that the Coffee Cup engine (although more expensive) is more exciting ... and the 'test tube' and marble engine less expensive in demonstrating a heat engine.
Posted: Thu Dec 24, 2009 6:37 pm
by stirling___781
How about using empty milk , cardboard cartons? The ones in Norway even have a screw cap hole which could be used for the piston. Now you have me thinking!
Posted: Fri Dec 25, 2009 1:24 pm
by k.huenig
Hi everybody,
I finished my Stirling engine cardboard kit, it was published by AstroMedia (www.astromedia.de).
Klaus Huenig
