Known engine attribute repository?
Postby shannonkeyannon » Sun Dec 20, 2009 12:18 am
Hi Guys and Girls,
I am interested in the physical properties of engines with known power output. If you have plans you are
willing to upload I am happy to work it out for myself. Can anybody fill in the following for a particular engine?
  • type: (Alpha, beta, other-describe)
  • Power output (mechanical at shaft):
  • Hot side temp:
  • Cold side temp:
  • Power piston displacement or swept volume:
    • Power Piston diameter:
    • Power Piston stroke:
  • working volume (volume in which working gas is heated and cooled:
At top of Heating Cycle (i.e. for alpha engine this would be internal displacer wall surface area when
displacer retracted to expose working gas to hot wall)
  • Heating surface area to volume ratio:
At top of cooling cycle (prob symetrical with hot SA as above.)
  • cooling surface area to volume ratio:
  • Total volume (Working volume + dead volume + power piston displacement):
  • Mean pressure:
  • Further comments such as number of pistons and their configuration:
I think a few have touched on it already, but I am trying to build up profiles which involve more detail than
hot side/cold side evaluations. Hopefully this might become a useful repository for myself and others to compare
different engines and perhaps expose inefficiencies in their design.
Many kind regards,
Shannon.
shannonkeyannon
First Name: Shannon
Last Name: Key
Users browsing this forum: No registered users and 5 guests
