Stirling engines used to generate electricity from wood burning stoves
- First Name: bernard
- Last Name: barnes
Does anyone know of a commercially available product that uses a
Stirling engine to generate electricity using a woodburning stove as
the power source?
the power source?
Response to Stirling engines used to generate electricity from wood burning stoves
I would also be very interested in information regarding a proprietary generator using woodfuel - I wrote recently seeking technical advice on uses of a Stirling combined with a charcoal retort as a possible solution to providing small scale poer generarion in rural locations in the 3rd world - I have not had any success in finding existing equipment and have embarked on a design and build project myself - this really is not my field so if you do find any info on "off the shelf" equipment I would apopreciate your passing it on - or failing this i would be happy to swap notes
- Last Name: barnes
Thanks David, im sorry to hear that you've had no response. It soulds on the surface to be such a great idea, it is surprising that it has not yet been developed. I'm afraid I can contribute nothing to your project, but if I hear of anything I'll let you know.
Bernard
Bernard
Electricity? from Wood Burning Stoves
The only Stirling powered device manufactured to run on old fashioned cook stove tops (wood or coal) is the "Lake Breeze" made in Canada. Sells in the $200 to $300 CN range. The fan blade is something like 12" or 14" and is used to circulate warm air throughout a small woodsland cabin. See URL and links at:
http://www.moderntradingpost.com/freebreeze/index.html
It is not likely to have enough power to generate more than a few watts of electricity.
- First Name: Dave
- Last Name: Weilacher
So this fan, 15 inches in diameter can move 200 cubic feet of air per minute. How much work is that? (in watts, hopefully)
There are no 'off the shelf' Stirling engines to operate on a wood/coal burning stove. A custom designed and manufactured engine would be too expensive to consider and in addition the power output would be inadequate except for very small requirements.
- First Name: Dave
- Last Name: Jinkerson
200 cfm would be about 15 watts. Hope this helps.
Hi I had the same idea here in france while we all have woood burning stoves ,i'm in the proces off building a Stirling engine woodburning stove to get some free electricity and if i succeed with a nice rendement i will be contacting some producers i will let you know the outcome
- First Name: jaime
- Last Name: pinzon
yo nesecito 10watts en 12 voltios , uds creem que podria utilizar este producto
- First Name: Robin
- Last Name: McCabe
you may be looking at the wrong end of the heat source. The waste heat up the flue in a outdoor boiler has to be 500 to 700 degrees.
the water heat is intentionaly limited, so as to not get into a boiling (steam, pressure) situation, but there is more than enough energy available, it is just being wasted up the flue.
if someone can gernerate power in the flue, these outdoor boilers, would become very usefull, right now they are a bit of a toy, because owners are still dependant upon the power grid, to move the hot water into the house.
