cylinder sizes ???
cylinder sizes ???
Postby custom_200sx » Tue May 24, 2005 9:37 pm
I’m new at these engines and was wondering if it is possible to
build an engine that would work using a cylinder 110mm in diameter
by 180mm long, what would the size of the power cylinder need to be?
Is it even possible with this length or will i need to cut it down?
Is there some kind of ratio or formula I should follow? Any
information will be greatly appreciated. Thanks
custom_200sx
First Name: bob
Last Name: frank
Response to cylinder sizes ???
Postby danguiness22 » Mon Nov 06, 2006 11:30 am
Hi, The lenght of the displacer cylinder should be 3 times the diameter.
danguiness22
First Name: Daniel
Last Name: O'Connor
Postby schiz0preni » Tue Mar 17, 2009 12:28 am
for displacer the dimension should be 3:1 (length to diameter ratio) and also the swept volume ratio should be 1.33:1(Vswept for displacer to Vswept for power piston)
schiz0preni
First Name: Qamarul
Last Name: Hazimin
Users browsing this forum: Google [Bot] and 3 guests
