What equation would be used to size a Stirling engine
davidashton
Last Name: Ashton
Post by davidashton »
Presumably there is an equation that could take a Stirling engine of
a certain size and it would calculate the hp and torque produced from
it. Conversely, there should be a equation to size a Stirling engine
to meet a criteria of 100 hp, and 200ftlbs of torque for instance.
What is that equation or series of equations, and can you recommend
books?
fvnorman
First Name: Franco
Last Name: N
Response to What equation would be used to size a Stirling engine
Post by fvnorman »
You can use the Beale formula to estimate power to a first approximation. You input the mean engine pressure and the swept volume of the pistons to get the power.
Torque is simply (power)/(2*3.14158*freq), where freq is the engine rotational speed in Hz. If you input power in watts, the torque will be in newton-meters.
Here's an explanation on power estimate using the Beale formula:
http://newenergydirection.com/blog/2008 ... -estimate/
