Piston rings, rulon LD, where to buy?
teemu.hayrinen
First Name: teemu
Last Name: hayrinen
Post by teemu.hayrinen »
Hello!
I'm trying to get 500w out of my alfa, so far not even close but here
you can see it running http://www.youtube.com/watch?v=9Bf6mhfeUH0&eurl=
Piston diameter is 63mm and now I'm seeking to find small pieces of
rulon LD sheet, 0.25mm thick, to try to make lip seals. I got these
informations from Mr. Andy Ross's book, but does anyone know if I
needed a thicker material to piston with 63mm bore?
63mm should be a standard bore, I would be happy to try a factory made
piston rings if there was any suitable low friction / high temperature
rings available? Is there any?
Teemu Häyrinen / Finland
A Google search for "Rulon LD" now referred to as "Rulon LR" resulted in several hits.
has an email address and phone number, is one of the better.
teemu.hayrinen
First Name: teemu
Last Name: hayrinen
Response to Piston rings, rulon LD, where to buy?
Thanks!
It seems like the rulon J would be the most suitable material? I keep on searching.
-T-
pds
First Name: Per
Last Name: Sollie
Post by pds »
Try Vespel material 211. They work. Problem is the material is costly. You can get them in Norway and Sweden.
dbiering
First Name: Dave
Last Name: Biering
Post by dbiering »
There are several Rulon materials that can be used in piston ring applications. LR and J are common but there are newer grades that give better performance. Contact www.tstar.com and go to Ask The Experts. They can help.
