Stirling engines used to generate electricity from wood burning stoves
Postby synapticconnections___9380 » Fri Sep 24, 2004 12:33 am
Does anyone know of a commercially available product that uses a
Stirling engine to generate electricity using a woodburning stove as
the power source?
First Name: bernard
Last Name: barnes
Response to Stirling engines used to generate electricity from wood burning stoves
Postby tokol13 » Fri Sep 24, 2004 8:24 am
I would also be very interested in information regarding a proprietary generator using woodfuel - I wrote recently seeking technical advice on uses of a Stirling combined with a charcoal retort as a possible solution to providing small scale poer generarion in rural locations in the 3rd world - I have not had any success in finding existing equipment and have embarked on a design and build project myself - this really is not my field so if you do find any info on "off the shelf" equipment I would apopreciate your passing it on - or failing this i would be happy to swap notes
tokol13
Last Name: Davis
Postby synapticconnections___5538 » Sat Sep 25, 2004 5:11 am
Thanks David, im sorry to hear that you've had no response. It soulds on the surface to be such a great idea, it is surprising that it has not yet been developed. I'm afraid I can contribute nothing to your project, but if I hear of anything I'll let you know.
Bernard
First Name: bernard
Last Name: barnes
Electricity? from Wood Burning Stoves
Postby stan.hornbaker » Sat Sep 25, 2004 8:55 am
The only Stirling powered device manufactured to run on old fashioned cook stove tops (wood or coal) is the "Lake Breeze" made in Canada. Sells in the $200 to $300 CN range. The fan blade is something like 12" or 14" and is used to circulate warm air throughout a small woodsland cabin. See URL and links at:
http://www.moderntradingpost.com/freebreeze/index.html
It is not likely to have enough power to generate more than a few watts of electricity.
Postby daveweilacher » Fri Oct 15, 2004 11:43 am
So this fan, 15 inches in diameter can move 200 cubic feet of air per minute. How much work is that? (in watts, hopefully)
daveweilacher
First Name: Dave
Last Name: Weilacher
Postby stan.hornbaker » Tue Oct 19, 2004 8:06 am
There are no 'off the shelf' Stirling engines to operate on a wood/coal burning stove. A custom designed and manufactured engine would be too expensive to consider and in addition the power output would be inadequate except for very small requirements.
Postby d.jinkerson » Sun Mar 20, 2005 1:20 pm
200 cfm would be about 15 watts. Hope this helps.
d.jinkerson
First Name: Dave
Last Name: Jinkerson
Postby otje112 » Mon Oct 10, 2005 11:35 am
Hi I had the same idea here in france while we all have woood burning stoves ,i'm in the proces off building a Stirling engine woodburning stove to get some free electricity and if i succeed with a nice rendement i will be contacting some producers i will let you know the outcome
otje112
First Name: leon
Last Name: van der bend
Postby worldtechnology2002 » Wed Dec 27, 2006 6:33 pm
yo nesecito 10watts en 12 voltios , uds creem que podria utilizar este producto
worldtechnology2002
First Name: jaime
Last Name: pinzon
Postby robin-mccabe » Fri Feb 08, 2008 4:16 pm
you may be looking at the wrong end of the heat source. The waste heat up the flue in a outdoor boiler has to be 500 to 700 degrees.
the water heat is intentionaly limited, so as to not get into a boiling (steam, pressure) situation, but there is more than enough energy available, it is just being wasted up the flue.
if someone can gernerate power in the flue, these outdoor boilers, would become very usefull, right now they are a bit of a toy, because owners are still dependant upon the power grid, to move the hot water into the house.
robin-mccabe
First Name: Robin
Last Name: McCabe
Next
