Stirling Heat differential Summary of Links
Postby craig___4888 » Mon Jan 19, 2009 5:49 pm
Hi Stirling Enthuisists.
I have been looking at the many links on Heat differential, and
thought is nice to centralise them in one place via a set of links
href="http://www.stirlingengine.com/bboard/q-and-a-fetch-msg.tcl?msg_id=00003n&topic_id=4&topic=Power-producing+Stirling+engines">Sizing
a Stirling engine
href="http://www.stirlingengine.com/bboard/q-and-a-fetch-msg.tcl?msg_id=00004J&topic_id=4&topic=Power-producing+Stirling+engines">Temperature
differential to power ratio
href="http://www.stirlingengine.com/bboard/q-and-a-fetch-msg.tcl?msg_id=00004k&topic_id=4&topic=Power-producing+Stirling+engines">3-5
kw Stirling for solar application
href="http://www.gulfcoastchp.org/Technologies/Power/StirlingEngines">Article
href="http://www.stirlingengine.com/bboard/q-and-a-fetch-msg.tcl?msg_id=00003Q&topic_id=4&topic=Power-producing+Stirling+engines">Temp.
differential sources
craig___4888
First Name: Craig
Last Name: Lambie
Postby stan.hornbaker » Mon Jan 19, 2009 6:34 pm
Our thanks to Craig for ferreting out the links in his post for easy access to the information referenced.
Response to Stirling Heat differential Summary of Links
Postby craig___4888 » Tue Jan 20, 2009 2:52 pm
FYI a question I posed to a Stirling Engineer.
Hi there,
As experts in your field, I would like to ask your opinion on the
viability of the following:
A Stirling Engine that is powered by decomposing Organic waste, of
which heat differential is between 20-40 d C.
http://www.css.cornell.edu/compost/monitor/monitortemp.html
http://www.stirlingengine.com/bboard/q-and-a-fetch-msg.tcl?msg_id=0000O6&topic_id=4&topic=Power-producing+Stirling+engines
I was thinking a small Stirling engine could produce some power from
this differential, but the amount I don't know?
Do you think this is a viable idea? What sort of power output would
the system have?
I look forward to your reply.
Regards
Craig
Mr. Lambie,
The merit test should be done on a pure thermodynamic concepts, even without the Stirling in mind. As such, 20C to 40C difference is very very low to operate a machine, any machine. If it can be made to run (???) it will probably be extremely big and inefficient for the amount of power produced.
Sunpower, Inc.
craig___4888
First Name: Craig
Last Name: Lambie
Postby stan.hornbaker » Tue Jan 20, 2009 7:06 pm
It is like Sunpower stated. Don't expect much from a 40 to 50 deg. C temperature differential. Maybe just enough to run the engine at no load. Take the time to read through some of the previous threads to get a better sense of what is involved.
