waste heat recovery from micro turbines
Postby clrksdc » Fri Aug 08, 2008 12:43 pm
Would it be possible to run a Stirling engine(to produce electricity)
from the waste heat (200-300 Deg.) of 2 digester gas suppied micro-
turbines?
clrksdc
First Name: Scott
Last Name: Clark
Waste heat recovery from micro turbines
Postby stan.hornbaker » Mon Aug 11, 2008 1:16 pm
I assume you have 2-300 deg.F waste heat available since you ask about applying it to Stirling engine.
Stirling engines are designed around the absolute temperature difference in deg. Rankine or Kelvin. Your cooling water or heat sink temperature is also needed.
In general the a waste heat stream in this temprature range would not likely be advantageous.
Postby stan.hornbaker » Tue Aug 12, 2008 1:19 pm
A more efficient hybrid system for utilizing the waste heat from a turbine to drive an electrical generator is described on pg. 60 of the September 2008 issue of Popular Science magazine. A patent has been applied for covering this system.
Return to Waste Heat
