20C-100C
Posted: Sat Apr 18, 2009 8:32 pm
by jefflee2897
Hi,
Do you know of any mfg that makes a Stirling Engine that operates in
the range of 20C-100C, so a delta T of 80C?
Thanks
20C-100C
Posted: Sun Apr 19, 2009 11:16 am
The answer to your question as asked is a flat NO. There are model (toy) Stirling engines that operate on delta T's in this range.
Presumably you want to realize some operating expense savings from utilizing waste heat from some kind of processing equipment.
Questions: Why a Stirling engine, anything in particular?
Would any reasonable other solution be acceptable?
Response to 20C-100C
Posted: Sun Apr 19, 2009 12:22 pm
by jefflee2897
The reason I ask specifically about Stirling Engines in this temperature range is because of the quiet operation of these engines compared to others. If you could suggest another engine with a low auditory footprint, it would also be appreciated.
Are there any reliable "toys" that operate in this range that can be cooled by tap water for faster cycling?
Posted: Sun Apr 19, 2009 2:19 pm
The second preceeding this one refers to Rankine cycle system that may be applicable to your needs.
There are currently two Rankine Cycle systems entering the market. One uses
Ener-G-Rotors, Inc. for details.
Posted: Mon Apr 20, 2009 11:14 am
by jefflee2897
I saw your posting on matteranenergy and ener-g-rotors before I posted to begin with. Matteranenergy is too large of a system and would not interface well with my system.
I know Deluge Inc has an engine, but I was wondering if there were other Stirling engines.
Posted: Mon Apr 20, 2009 12:34 pm
Could you be much more explicit as to all aspects of the conditions of your application?
