Solid State Heat Differential to Energy Conversion
Postby andys » Tue Oct 24, 2006 5:42 am
I know that this forum is all about Stirling, but I though it would
be the best place to ask if anyone knows of a process by which heat
differential can be converted to electrical energy without a
mechanical intermediary. Like electron flow between poles of a
battery, what energy moves between the hot side and the cold side of
a heat conducting material as it distributes the heat? Is air the
only medium that people have tapped for this? Where should I look for
more information on this?
andys
First Name: Andrew
Last Name: Shapiro
Response to Solid State Heat Differential to Energy Conversion
Postby bptdude___2569 » Sun Mar 02, 2008 8:51 am
yes, it is called the Peltier–Seebeck effect.
Here is a little wood stove top fan using it.
https://www.gyroscope.com/d.asp?product=ECOFAN2
From what I have read, it is usefull for non-power producing application, such as sensor electronics and signal devices.
While much research is done on photon-electric conversion, there is not much activity in thermal-electric conversion.
Postby paraplegic.racehorse » Sun Apr 05, 2009 7:02 am
What you described is, essentially, a thermocouple and many automotive sensors already use this to generate low-voltage signals which are then processed by the onboard computer for fault monitoring.
The only place I can see such a comparative thermocouple useful is in basic heat exchangers such as used in refrigeration applications. There, it would be useful as a state-monitoring device to watch for a decline in efficiency and, thus, when to add or replace the refrigerant.
First Name: Charles
Last Name: Reynolds
Return to Waste Heat
