HI Joe,
Reply to your comments below.
Geoff
If you have anywhere close to a working engine with even close the power you say, it would be a miracle. I went over your new design, I sorta followed your equations, and I think the machine probably is not going to even turn over!
GH - Well it is good to do the physics first - see if it works in theory. But yes, I don't expect it to work. However I know I will learn a lot in failing - and have a lot of fun in the process.
It is heavy and requires lots of external system support. It will also be difficult to sell this thing, since it contains so much lead, which you will keep molten.
GH - By a lot of external support you mean that the engine needs to pump itself up to and maintain its working pressure - not that hard really. Lead is good because it has high heat transfer and it does not explode with air. SO a lead (hot side) water (cold side) is useful as you can just use air to keep it pressurised. But I am just experimenting. There is also Hitec salt that can be used on the hot side.
I also see you are asking for free information for a machine you are trying to patent.
GH - I believe in free access to free knowledge. I patent things just so i have some control over their use. I have no interest in money really (I have enough to live simply). My motivation is 3 fold, curiosity / challenge, I don't have mains power so it is useful for me, and I like its humanitarian 3rd world possibilities.
If you want to use any of my ideas then just discuss with me - as long as they are for uses good for humanity then I am happy!
I understand you are in the middle of a project and very excited, so my grand theories get skimmed over. So, let me review what happens with other commercial attempts at a power producing Stirling.
GH - Too true. But this is a post on my design for Stirling engines. If you want my thoughts on your design ideas just post them in a new thread and I will gladly reply (for what it is worth!)
For one, most have to heat the thing so hot, they reach a limit that causes metal fatigue fairly quickly. Your design of internal heating will help, but you still will not have enough heat, even though the theory says you will. Most of the equations out there are static, in the sense they really do not watch the real dynamics of all the forces involved.
GH - Philosophers are a pain in the ass - because they will always ask you for the source of the truth. So where is your source of truth? You may well be correct - but I prefer to experiment to confirm things. And i have a cool little laser pointer temperature meter that measures to 500C so today I am going to experiment with lead and measure the air temperature coming out of the hot side using different dipping materials and also just injecting the air into the molten lead. A bit scary - but a lot of fun.
Also, the second most common method of getting power from a Stirling is to compress the gas. You do this, and continue to feed helium with an auto air conditioning compressor. Even if you try to recover the helium, I see you do know it is going to bleed out the cylinder walls, and an ongoing supply is not a reality. You also will not come even close to the internal pressure of the working gas requied. To maintain the kind of pressure, you will certainly need more expensive machinery.
GH - If I use helium then the motors will be put in the big cylinders (400mm D) to prevent leaks and it will not use an external pump. I plan on only using external pump if I use air.
It is a very novel design. Please be carefull and do not lead poison yourself, or burn yourself.
GH - Yes, this is my worry. I try to think first and be careful, but we humans are blind to obvious things, so there is always risk.
My assesement can be summed up as, to the Stirling trying to get power, the engine is heavy to move and light to hold up.
I can suggest the following. Give up on it, and try this. Find the project from MIT that used old automobile parts, just like you are using, that built an organic Rankine cycle engine successfully. I bet you could improve on it, going in the direction you are.
GH - I will search this later. Thanks. And I cannot give up on something that I am having such fun thinking about. I love experimenting / creating. I am surprised you wrote that.
At least you are using the old noodle!
GH - I try. I accept I am stupid - to me this is simply an aspect of our animal evolution.
If I lived in Oz and had all that sunshine and junk parts, I think I would pick a much simpler solar powered steam engine.
GH - Well solar voltaic panels are the obvious future and are coming along in leaps and bounds (search thin film plastic solar panels). But they are still 5 years away from being cheap.
My last tip and post for you. Study using a liqiud for a working fluid. It doesn't expand as much, but provides far more power for less movement. It also moves slower, and would be less dangerous. Your design for internal heating and cooling will work much better too!
GH - Yes the forces would be enormous but over very short distances. Worth thinking about though.
Thanks Joe. Don't be put off my my blinkered enthusiasm for my own ideas! I am here to help and share knowledge, to experiment and learn. I appreciate you being part of that. Very much!
Cosmic cheers,
Geoff
