High Temp Epoxy Piston Rings????
burnit0017
First Name: Lauri
Last Name: Koponen
Post by burnit0017 »
Greetings, I am starting a project using a 2 cylinder V air compressor and try to convert it to Alpha Stirling. I found some links were small projects created there own pistons using high temp epoxy. Using their idea, I am going to try to replace the piston rings with high temp epoxy and add a dry lubricant between the high temp epoxy rings Hopefully this will give a good seal and reduce friction. Has anyone tried this before? Best regards
Concept Drawing
Concept Drawing
DIYStirlingGuy
First Name: Justin
Last Name: Sparks
Contact:
Re: High Temp Epoxy Piston Rings????
Post by DIYStirlingGuy »
Wow, what a great idea. I think this will work for engines that run at relatively low temperatures (200-300 Fahrenheit). Let me know if it works out.
DIYStirlingGuy my site: http://diystirlingengine.com/
