I am in the design phase of installing a DHW and home heating system
via solar hot water. In the summer the system will produce a lot of
excess heat that I won't be able to use, so I am faced with either
creating a heat dump, or finding a use for the heat.
I was wondering, would it be possible to use hot water to power a
stirlining engine strong enough to circulate water through a pool filter?
Residential Usage of Stirling Engines
Response to Residential Usage of Stirling Engines
Would it be possible? Maybe. Would it be easy? No.
The temperature of the solar heated water is not high enought to operate a Stirling engine with the output needed to circulate swimming pool water through a filter at the rate required if at all.
